ste8
hi marco and still thank you,What do you want? but you get the costs.
and the offices or move them more towards "the tip", not so directly close to the flange. (as I posted you in that example flange image)
risk that the or are "pizzichino" in the edge of the hole or, if the edge soaks it too, that they do not lay "correctly crushed" to hold.
and it's easier to make the cutting at the lathe if you're not really attached to a "wall"... and you have to respect the predetermined dimensions to make those locations; check the catalogues.
Mar
o-ring locations moved as from your design of some millimeter.
For the other matter, for now I prefer to keep it like this!
Thank you again!
