genesis1975
in the post #96 you said it would erase me only min-00158_mon and pos162h18_mon? Would you still erase me only copies not the originals, would you?
those mentioned are present in the mounting carella, those in the original carella are called equal?in the post #96 you said it would erase me only min-00158_mon and pos162h18_mon? Would you still erase me only copies not the originals, would you?
I can't have two files with the same extension they call in the same way.If the two that are called the same were in the same folder and I delete one... you delete the other too?
is not what you are talking about, but files with the same name in different foldersif they have the same name outside can be equal but also different
ThenIf it's called by different name, it's obvious that I only erase one, it considers them different files... even if they're the same.
which means, by interpreting why you are not able to respond without making turn of words and subtlety, that the file in the assembly folder is called min-00158_mon while the one in the ortiginal folder is called differently, perhaps min-00158.Okay the first part.. .
osando also put as finalbut the files that are called equal in two different folders come from each other?
And should I know? Did I work with your files? *non so
@genesis1975if you are mentally tired you stop, you do anything else or you go to rest and you do not continue to ask questions and to ask for answers that at that time you cannot metabolizelast night when I was told the last things I had to understand those before, and I was tired
Post#102Sorry but now I'm home and I don't have windows explorer....if you want to answer me for now answer the post #85 and #86
Since you've never made it learn to quote messages (select the text and you've got an icon like that of the image or directly press the consideration below right) and the phrases you respond to so that you can make it clear to what you're referring to and then don't equire your answers and if you forget to fully formulate a post edit it (you have 15 minutes to do so) and don't write others without indicating that they are the continuation of the previous one.if you kindly answer me to the last post, the #101
