meccanicamg
for this reason, and also seen the irresponsible costs, in the mountain gears always bearings with two rotating roller crowns.Keep in mind that the nup bearing becomes axially rigid so you will have to allow the scoring for expansions leaving the outer ring free.
the nu bearing need two shavings of locking outer ring,
as it was said, obtained directly in the case without space, if you opt for the case divided in two half. In this case the nu bearings work better because the inner ring is free to flow without loading the flat face of the rollers against the reservoirs, as happens in the nups, which push the outer rings because of the expansions. It is intuitable that in this case there is a friction for crawling between flat surfaces, and therefore at this point it would be necessary to use ball bearings or barrel rollers that explicate the thrusts for volve friction.
therefore also consider the calculation of the bearing to make subsequent choices.
the gearboxes to save they mount conical roller bearings because they sell millions of pieces.
until now I have done only one reducer with two outputs that has bearings to a crown of balls....with ratio to an i=3 stage and little torque to be transmitted....a big toy like a children's backpack.
