luca984
1 - since many times I have to use I am command alternating it to the assignment command when I go to make a filling you create a draft that stona how do I delete is drafting? ?
2- and better use the replenishment command (e.g. to combine a surface extrapolated in curvature and a tangency or join a radius to a flat surface) or connection? ? ?
3- multisection command then what's the point? ?
Thank you
Thank you
