numero1
quoto :finger:Of course, and I want an autographed copy![]()
Come on, a few stories. When you're done, if you're interested, we can talk about the horizon.quoto :finger:
You can start. .![]()
But without exaggerating, half a page a day can be enough...:hahahah: :hahahah: :hahahah:
How human she is.... (with imaginary voice) :wink:But without exaggerating, half a page a day can be enough...![]()
even less than half page can sufficeHow human she is.... (with imaginary voice) :wink:
even less than half page can suffice![]()
I could not disappoint "friends" like this! :biggrin: but before facing the horizon. . .
ordered by the nigeria in 1977 (a meko 360; the versions are: meko 100 “corvetta-pattugliatore”; meko 140 “corvette”; meko 200 “fregata”; meko 360 “fregata- huntership”).
the solution capable of satisfying these requirements was that of a hull “container” to be filled according to the need, with modules containing the necessary to fulfill the desired missions. the modules, of standardized size iso and having variable lengths from 3 to 4.5 m; (the functional modules for the combat operating power station are provided in the form of bases on which the different consoles are then mounted), can contain weapon systems, sensors and even consistent parts of the unit. beyond their physical and structural aspect, they are constructed separately from the unit itself and are almost completely independent; are installed in the platform in appropriate recesses and connected to it thanks to connections for electricity and interfaces with onboard systems, including combat systems, i.e. connected with the necessary utilities (electricity, conditioning/ventilation, cooling water, communications, information distribution network if not already provided) through interface elements also standardized. also auxiliary equipment, such as air conditioning and ventilation systems, generators, and as much as possible, can find place on pallets specifically pre-set and feasible in the form of closed containers, structures with open sides, bases and complete tree (as we have seen with the unmast). the concept “modular” therefore requires an optimized design to receive the container of which the dimensional characteristics are known. some modules can be simply installed on the blanket and on the rails, others will be arranged internally therefore, they will have to be prepared suitable openings; In both cases, reinforcements of the structure must be prepared. This forces us to resort to larger dimensions which, if on the one hand require greater power (at the same speed required), on the other contribute to increasing the survival qualities. . .In my opinion the first was a very serious reason, the discriminant lies in those few years of difference between one and the other:Italian ships were superior as performance to mekos but two factors occurred for our negative industry. the first was purely political: being at the time the Argentine a dictatorship of the right, the workers of the Italian yards protested "vivaciously" threatening to boycott the buildings (which instead did not happen then for the cession of the wolf to the iraq); the second fortunately was a more serious reason.
Okay. but I remain of the idea that politicians have to make politics and yards have to make ships, that if then we are not to sell, we only benefit foreign countries who see us as smoke in the eyes and expect nothing else. in fact the Germans did not scruple and sold 4 with option for another 2.great, thank you but......
1978 and 1981 if I understood correctly...
and also in the fact that the Italian presence in Argentine was very wide and very felt.
with unchanged estimate![]()
(six.)So can I move on? :tongue:interesting, here are![]()
e la “esbern snare”
ranked “arm operations support unit” while the FS produced the “peder skram” class, real combat units configured for air defense. Therefore it can be said that the two projects have a common root and in fact the size of the platform confirm it (the size of the hull is 137m for 19,5).
of the naval shipbuilding damen schelde shipbuilding, a Dutch ship yard with headquarters in flexinga. the sigma project (ship integrated geometrical modularity approach) offers a range of platforms ranging from 50,4 meters to 148 and 9 to 15 meters wide, with displacements up to 5000 tons. simply by adding standard modules of 7.2 meters you get units ranging from corvettes to ocean patrols to frigates. Unlike the meko project, which does not alter the platform and is seen as a container to be filled with modules, sigma exploits the opposite principle and the platform transforms. you can have 2 or 4 diesel, or 4-6 generators for an electric drive, or still tag. to each of these configurations you can combine two fixed or variable step propellers or “water jet”. here more than on reconfigurability, it has focused on the fact that the construction of the modules, happening at the same time to the platform, makes it possible to install the equipment chosen by the customer reducing the times of construction and the costs. Starting from a minimum configuration of 7 modules you get a unit of 50.4 meters per 9, while reaching 20 modules, you get to more than 148 er 15. the sections are standard and each has its own bulkheads with tinned doors and are almost complete with any other structural component.You can't, you have to.........So can I move on? :tongue:
I should have something in the office. I'll watch tomorrow.can you have some photos of modules, pallets, and assembly phase?
motorized with two diesel semt pielsticks of 8.190 kw each that allow speed between 14 and 28 knots. the combat system is the “tacticos” of thales which also provides the radar “mw08” for the discovery and tracking of the targets, both surface and air, and a radar for the direction of the shooting “lirod mk 2”; to these are added a “bridgemaster” navigation radar of the “sperry” and a “thales kingklip” hull sonar. have a 76/62 super-rapid, two binati launchers for anti-shipping missiles mm-40 exocet, two tetral quadruple launchers for mistral anti-aircraft missiles and two anti-som torpedo launchers, as well as a couple of 20 mm. a stern is present a flight bridge for operations with helicopters. the crew is about 80 men
that, although different, present many similarities in weapon systems and sensors, including aaws.
