are images that I had collected here and on the internet from the various sites "shipvattelapesca" or "navychilosà" and stored in my "database" which, as I often promise but never do, would need a reorder.Isn't it much?
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
as someone said......
All right, exatem. Thanks and quiet.
Good evening
like all modern naval units, also the lcfs indicate the care put in an attempt to contain the radar track; the same attention was also placed on those of other type (thermal in particular) and on passive safety through the subdivision of the unit in seven main compartments and a high level of protection for the vital areas. the platform is one of the smallest, “baked” only by the sachsen; 144 meters long for 18,8 wide and with a fishing of 5, full-load displacement reaches 6,050 tons.
and then continued with fried class "fridtjof nansen"
(follow...)Hold on. I'm almost done! :tongue:I turn my head:
built between ’63 and 67, they begin to denounce all their limitations beginning with the inability to face new threats and to ensure the Norwegian participation in international missions.
in practice, of copies in a reduced scale.to me has already fallen and rolled under the table....... :I turn my head:
I turn my head:
Ohhh, are you always complaining?to me has already fallen and rolled under the table....... :
so innovative in some cases, a question to be born... what advantages, compared to the classical monohull displacement that dominated the scene until now, can bring new forms as in the case of the trimarano lcs or the famine “wave piercing and tumblehome” of the zumwalt?
were perhaps the first to introduce the inclined superstructures towards the interior that created a edge (chine) in the intersection with the walls traditionally tilted towards the outside. But this means that if the ship rolls, at a certain time the superstructures will be vertical compared to the sea therefore, well visible from the enemy radar.
and the reduction of the superstructures also increases the ability to survive because the anti-ship missiles generally affect the superstructures or the high part of the walls, then arrange the vital spaces of a warship in the low areas of the hull increases the survival skills even if it requires a greater volume immersed, from which the use of the solution "tumblehome". the paradox is that a ship carefully designed to be stealth, will be greater than one by conventional design.And you like us a little bit...... :tongue:Ohhh, are you always complaining?
and I can't even fuck you because you're my audience...:biggrin:
We make you feel the perfide pirate commander of a ship (always pirate obviously) that angaria (you can say) his crew.
and the france that had to replace the class “jean bart”
and the class “suffren”,
they agreed to give life to the common a3f program (anglo-french future frigate) for the realization of a ship with very advanced characteristics and addressed to the aerial defense. the preliminary agreement was signed in 1991 and confirmed in the summer of the following year. in December of the same year also Italy entered the re-designed program cgnf (common new generation frigate) and later “horizon”. responsible for the project were malcom mcintosh, yves sillard and for Italy the ammunition that established a fair division of the costs of development and construction proportional to the number of units to be realized. at the time it was thought to build even 22 so divided: 6 for Italy, 4 for France and 12 for the great brethren. in the estimate of costs, between 6 and 8 billion pounds, was excluded the missile system which would have weighed considerably on the final price. from the feasibility study a ship of 6300 tons, 140 meters long and about 20 wide that would be developed in parallel to the French-Italian fsaf program (future surface air family) relative to a new family of surface/air missiles and a medium-range naval missile.
while the British would install the sampson (type 1045).
(follow...)
after the description of the long “management” of the project, we now see the characteristics of the two units.
gas turbines are two general electric – avio lm 2500 from 20,5 mw each.
are installed in soundproofed containers and equipped with electronic control units developed by the avio, have reduced dimensions and weight. are of the same series of those boarded on the cauliur with different calibrations. the lm 2500 was produced in more than 2000 specimens but compared to those embarked on the master class, they had over 300 modifications.
divided into two blocks at the height of the blanket due to the presence of the entrances of the areas destined to the supply in the sea. There is also a large portal for easy loading/unloading of materials. on the sky of this tuga are the launchers for the anti-ship missiles we will see later. the prodiero block is dominated by the large bridge overstated by the “must” that houses most of the sensors and antennas of the ship. immediately behind this truncated pyramid, it is slightly disapproved on the right, the central tree with its antennas for communication and at its side, the imposing fumaiole of the prora machines strongly inclined to the outside. passing through the central tuga, there is the stern block with the second chimney tilted from the opposite side and the large tower surmounted by the antenna of the radar lrr s-1850m.
a small superstructure on the right side over the hangar and serves as a base for the 76/62 super fast. the blanket ends with the flight bridge of 494m2, studied for the use of day/night also under adverse conditions of an eh-101 thanks to the tc-asist of the Canadian company indal technologies in collaboration with the calzoni (a nhf-90 on the French with system samahe of the dcn). the hangar can accommodate and support an eh-101 or a nhf-90. for control operations by teams of specialists, the ship has a fast boat that can be put to the sea and recovered from stern as well as two rigid bark gums housed in two recesses of the poppiera superstructure and protected by antiradar shutters.
are in possession of the sophisticated and innovative flight control system called “pif-paf” that guarantees high manoeuvrability, and an advanced driving system that if initially is inertial, after receiving flight data from the epar, uses an active “seeker”. these make it useless, contrary to the standard/exsm American system, dedicated illuminators. the aster is a missile with a 0.18m bistadium propulsor in diameter and differs in versions 15 and 30 exclusively for the booster. in version 15, 4.2 m long and weighing 310kg at launch, the aster reaches the mach 3 3 has a range up to 30km and 13 of altitude. the aster 30 is 4,9 meters long, weighs 450kg, can reach 4,5 mach and has a range of 120km.
(follow...)
equipped with a stabilized antenna 8.2 meters long and 6.2 tons heavy, which rotates at a speed of 12 g/min, allows to discover and track 1000 targets. This is a great power equipment and allows accurate three-dimensional information on potential threats allowing the aa system to “enter” to the target as soon as possible.
While on the pens as a multipurpose rocket system the French sagaie had been installed, here it returned to the sclar in its latest version, the "h" remotely controlled, present in two specimens. the new multicell complex weighs without ammunition 1150kg, can launch 20 105mm rockets or 15 from 105 and 4 from 118mm and also uses rockets intended to transport anti-ship missile deceptions.
for the antisom struggle, in addition to the helicopters boarded, the doria can count on two binati launchers “eurotorp mu-90 impact” for 324mm torpedoes with capacity up to 25km,
that are part of the slat system (systeme de lutte anti-torpille) which is based on three main components: the search module (alert) with sensor towed sonar and hull sonar, a threat assessment module (rate) that analyzes, evaluates and decides, and the module for countermeasures (cmat) constituted by a multicell launcher to 12 tubes, for electro-acoustic decoy able to create a “image” sound similar to that of a ship or jammer type that emit signals capable of obscure the head.
Last but not least the fics (full integrated communications system) that uses satellite shf/uhf sicral systems, hf, vhf,uhf military, vhf icao, vhf imm, inmarsat, metoc and gmdsss and datalink multitactic system.
