project ladice
  • Thread starter Thread starter Exatem
the wheel of prora is generally (in iron constructions) a forged bar, laminated or in some cases, melted. the section is to u, v and sometimes to t. the bending of fitting should be tangent to the line of the building plan. the radius of the connection.... can be constant or grow from below to above.
Do you take, on a larger scale, what is the straight of the rudder fin? :TIMONE 01.webp TIMONE.webpI'd do it by telling the length "out of everything."
Marco:smile:
p.s. .
Do you take, on a larger scale, what is the straight of the rudder fin? :View attachment 16642 View attachment 16643I'd do it by telling the length "out of everything."
Marco:smile:
p.s. .
Sort of. it is not so "full" because developed for the meters of the cutter would weigh a little too much. It's more like a u with a plate in the middle. --)I don't know if it's clear. Now I don't have the scanner (he killed himself) but I'll put it in the morning. I meant the length ft.
I sent you all the engine board.
pp.ss your rudder assumes an increasingly "interesting" aspect. :wink:
sublime pluralis maiestatis:smile:
He practically did everything.
Marco:finger:
If I had not your support (and patience) technical/moral/educative I would be miserably shipwrecked between extrusions, lofts and sweeps...
we reach 23 knots All the way.
you have to find the reducer (at least 2:1) because 600 rpm are too many.
Hello dragon,
so make happy sampom.
I already have the reducer. He's always a wart. Is the propeller always the usual? can you post a file with even the inner part of the hub (coupling to the axis)?
I'll put some data tomorrow.
..any "projection":MEZZA POPPA.webp
We reach 23 knots.
hi dragon, well found:smile:.
this is the propeller we have provisionally mounted, obtained "drawing" your previous:ELICA D2850.webpView attachment ELICA.rarlook if it could go and tell us about the calettamento (the tree terminal has become a "flange", like the ram? )
Marco:smile:
How come the blades are cut to the ends?
I have no idea. I asked when I saw her.
and all these "unburdenments" what are they?
here you find the original file that in its time posted drag:
Maybe if I attach it better.
elica-f12-5-3500-d.zip
..simplely I took that, I climbed it to shred it and made the conical hole for the first tree (now it has changed); to me do not come out those claws like "gruviera":biggrin:.
Maybe because of my "meals"?
Want another format? I try with an iges:View attachment Elica 5-2850-D.rargreetings
Marco:smile:
size is becoming important, it begins to be difficult to grasp the detail from an image.. but in the meantime:POPPA 38mt.webpHello
marco
put this string in the search for English wiki.
uss makin island(lhd-8)
What a strange thing!
continua a dirmi: oops! this page appears broken
I'm out of this.Immagine.webpI'm not coming. .
I take advantage to communicate that we are not closed (with laodice) but lately I am a little busy (from one thing .... I don't get a word that makes the idea... But what makes me so...
Here we are. exa was "the friend." .:biggrin:
(Mr., if you read nothing, they're jokes. . )
Are you there?
I'm, and I've been, busy myself. but slowly I'm going back to the ranks.
Marco:smile:
