cacciatorino
: Jigggrin:::
[youtube]4zshinvykf4[/youtube]
I am sorry, but I continue not to understand; We're probably talking about different things.depends on what you have to do, my question is simple, the problem exists at least for what I do.
for the selection of the individual curves has already responded to you dario, for the extra clicks is simply because in the video I inserted both the creation of the hole, and the creation of the component pattern in the assembly environment, things that you, for incomparable reasons, preferred to escude from your video! :biggrin:I see in itself a sea of clicks and the selection of individual curves, am I wrong?
but it goes ... but how bad you are, we put it from scratch as well with the creation of the hole, which for inscrutable reasons sucks in the same way both in swx and in itself:biggrin: .... sketch, center ... axis, mo te fo see but me.for the selection of the individual curves has already responded to you dario, for the extra clicks is simply because in the video I inserted both the creation of the hole, and the creation of the component pattern in the assembly environment, things that you, for incomparable reasons, preferred to escude from your video! :biggrin:
seen the video, question:this and what does catia v5 hope to have centered the goal
1 realizes profile tube and curve
2 realizes hole
3 realizes sketch of points for matrix
3 realizes matrix using point shizzo
assembly
1 tube with pins
2 matrix reuse created in tubing and constraints with dedicated function
3 parametric change by disconnecting the matrix holes also moves everything in assembly in an associative way
allego video files
I hope I've been clear
for hunter: tonight I try to post from youtube
There were no doubts....solidworks
hole creation, set of holes, insert part, repeat along the holes
I don't know if catia is the case of which they talked to you but at the minute 01:31 of the rs4 videos you see the chiodini moved after the change of the curve and remain with the axis in the same orientation before the change, so not perpendicular to the surface of the tube.seen the video, question:
Would you be able to do it with holes placed on the "pipe" of the tube instead of on the side, and that they are perpendicular to the sketch of the loft in each point (I hope to be explained)? However it would be as in the example of the first video of the discussion.
the fact is that they told me, so I didn't check in person, that a very high-end cad fails when it has to do the nail pattern: basically puts one for each hole, but they remain parallel to the first inserted, instead of following the direction of the curve.
That I don't trust you, I make you the film, a man of little faith:but the component pattern in the assembly environment made in pro/e? When do we see him? And nx? :smile:
I'll take my friend to buy the new cell later! :wink:That I don't trust you, I make you the film, a man of little faith:
I think that the geometric repetition, the repetition of the swx faces the face from the 2000 truth or perhaps before. I've always seen her.In the meantime, instead of puxxettine, tell me if you can do this?http://learningexchange.ptc.com/tutorial/1382/creazione-di-serie-geometriche
you have seen, that when you connect two components and reopen the file loses the references because it does not know how to distinguish the two lines of a surface, so that then you use the edges and if you allow you to make a round on the same, goodbye my beautiful gigugin.I think that the geometric repetition, the repetition of the swx faces the face from the 2000 truth or perhaps before. I've always seen her.
I'm not even going to give you the video, and then I'm gonna drop your helmet.
p.s. oh, the guy who speaks in the tutorial sends two cast iron drones. You have to wake up:
p.p.s the type above says that geometric repetition allows you to select features that are not in order in the history tree (which he says we have to see but you do not see...) while repeating features requires that they are in succession.
with swx it is indifferent that they are in succession or not. changes cad :smile:
and "you know" that you would see this stuff that loses references when you open the file again?you have seen, that when you connect two components and reopen the file loses the references because it does not know how to distinguish the two lines of a surface, so that then you use the edges and if you allow you to make a round on the same, goodbye my beautiful gigugin.![]()
I'll see you as soon as I can:wink:tzè ... son of a minor cad :biggrin:
So, speaking of children of minors, you see a little that maybe now I see the deal directly to his creator... :wink:Here are the series components on curve (for what you love to wash and centrifuge phones).
in the first part, the components "sent" the holes series and with the "reference" option are automatically placed on the holes.
in the second part the series is referred to the only curve.
in this mode I point out that it is necessary to indicate the correct origin to the series to follow the holes correctly.
www.aureaservizi.com/archive/video_tutorial_proe/11_serie_curva_componenti/serie%20componenti%20curva%20creo.htm
and here max is right crushers, behave well, do it well is repetition.So, speaking of children of minors, you see a little that maybe now I see the deal directly to his creator... :wink:
from your video you see, because I will have a few hair but I have an eye, that the series of holes does not follow the normal to the guide gurva. especially at the end of the video, in the image I attach, the components are definitely out of alignment. You gave me a whole red pencil and you charge it.
I add, to further infiler, that me and hunt have both posted the video with in the order:in total the all lasts 1':30''. Other variations on the theme can be made after, first let us see what paste (frolla) :tongue: it is made to create and follow the instructions :wink:
- creation of the first hole
- Creazinone series of holes
- new creation together on the side
- first component insertion
- repeating the components along the series of holes
for punishment touches you a race lap of the trench in fighting order and gas mask:biggrin:
on the geometric repetitions I will submit a nice benchmark, but a dick is not robetta from old house.:smile:p.s. have you wisely glamored on the geometric repetition that seemed to be who knows what? :tongue:
