SHIREN
It's no!!!!!! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !
What do I read?
I was an artillery
Talk to us
m 107
amphibians like 113 etc.
Hello exa....... .
Good Sunday
You're right, maybe I talked about it in "over and under..." but I had to specify better.What's the end? :frown:
Look at that we don't slow you down, you know!
:3559:
What do you tell us about beautiful now?
jokes aside, what do you mean in the last post when you write:
"as systems boarded on “commandants”,
What are the commanders?? Did I miss what???
Hello, Enzo. Thank you.It's no!!!!!! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !
What do I read?
I was an artillery
Talk to us
m 107
Hello exa....... .
Good Sunday
How come? The French?a last curiosity...
the first French unit, the forbin, during the preparation presented problems of installation of the combat system and strong problems of rust. . what our units have not yet shown.[/CENTER]
I don't know who the fault is, frankly, I don't even know if it's totally true or how bad it is.How come? The French?
duty!Thanks for the exa answer, always precise and punctual :finger:
go, but there must be so many photos, I can't always be with the open seafaring dictionary:biggrin::wink::redface:What do you think? Interested?
ahia and what is......... .duty!
I found some material on the American ddg zumwalts (I mentioned earlier).
considering that this is an innovative project, I thought I'd spend some time before facing the cauliur.
You're right. to try to synthesize, I omitted a part making the speech confused.everything ok until now but......... .
but lockheed martin wasn't in the "blue" team, the defeated one?? ?
the hull measures 183 meters long and 24,5 meters wide. the dive is 8,5 meters. the height including the superstructure reaches 34,5 meters and the latter is over 60 meters long for 21 of width. the displacement should be 14,800 tons full load even if it is expected to reach 16,000 during the operating life.
the complete tower weighs 80 tons and below it is the storage ammunition 13.7 meters long and 9, heavy 160 tons.
(in the comparison image between zumwalt and other units of the us navy)I think they started with the usual idea of making the universal medium good for everything but then for technical impossibility and exorbitant costs they have mutilated more and more a project that had well other ambitions. at the end of all the units that had to be built will do very few, it seems three, making increase the unit price of each of them again.always very interesting, thank you.
I mean, synthesized, what could potentially be a great piece of ship is revealing itself for a grand failscions, if only you had thought a little better about how to make it + multi role.
Right? :
equally innovative the solution, indeed, more striking, offered by the group gd. on the basis of the experiences on the Australian fast ferries built from the austal, was proposed an aluminum trimaran with a very narrow central hull but with a very high stability offered by the two side boots in the center-piece. 127.3 meters long and 31.5 meters wide, has an immersion of 4.3 meters.
the third group instead proposed a solution inspired by the patrolman with surface effect “skijold” already used in 5 specimens from the Norwegian navy, aluminum and composite materials, able to exceed 50 knots.
in May 2004 the contracts were reduced to two, with the selection of lm and gd proposals to which a contract was offered for the realization of the project detail and the option for the construction of two units each. both hulls displace approximately 3000 tons and have large flight bridges. let's see them more in detail starting from project lm.
